Golden_HVAC
Dec 16, 2015Explorer
I used light duty plumbers tape, and it held up well for about 4 years. It is only 3/4" wide and about 20 gauge.
You could also use a electrical conduit clamp, or some sheet metal that is thicker and a bit stronger.
You might also be able to find some U-bolts in 4" size. Or buy some 1/4" allthread and drill holes into the frame, then bolt the tubes with the allthread bent around the tubing, and cut to length.
Good luck,
Fred.
Good luck,
Fred.
44,066 PostsLatest Activity: Mar 14, 2015
