Tycho
Sep 10, 2016Explorer
Understanding towing capactity for Ford Expedition
We are noobs to buying and owning TTs but we are learning. What continues to confuse us is the advice/research into what exactly is our max trailer capacity for pulling. What size trailer can we get. If I read the black and white numbers then it looks really good for us. But when I do deeper research including older posts on this board, I get really confused as I am not sure what we truly can and can't do.
Here is what we have for a TV:
2012 Expedition EL Limited (5.4L V8 and 3.73 Axel) with HD towing package (Trans cooler, Trailer brakes, class IV hitch).
The numbers Ford gives:
GCWR 15,000#s
Max Trailer size of 8,700#s.
Max tongue load of 890#s
Other numbers I have found:
Curb Weight: 5781#s
Maximum payload:1590#s
As an example TT, here are the specs on one we like the most so far.
UVW 5638#s
GVWR 7600#s
CCC 1962#s
Hitch Weight 639#s
Full length 33'5"
On the surface we look fine and should be able to pull it considering we are 1100#s under the max rating for our TV.
But if I do the math (I believe correctly...)
Curb weight + Max Payload + Trailer GVWR + Hitch Weight = 15,610#s
This means my GCW is over the GCWR rating if I was to fully load the TT and TV down. Does this then mean that I should avoid the TT and look for something smaller? Or since this is the extreme high end that I am ok?
The other concern I have is the tongue. If I again do the math, according to Ford I should be 10-15% of loaded trailer weight.
So calculating that it would be 760(10%)- 1140#s(15%). It will obviously exceed the rating of the tongue then at about 11%. So how do I interpret this? If I would go by the percents then I would be looking for a TT under 6000#s to accommodate the 15%. Why does the vehicle even get a 8700# rating. Confusing....
Are there other concerns I may be overlooking? Perhaps I missed something in my calculations and it is better than it looks?
GCWR 15,000#s
Curb Weight: 5781#s
UVW 5638#s
GVWR 7600#s
CCC 1962#s
Hitch Weight 639#s
Full length 33'5"
