mkirsch wrote:
scootsk wrote:
Thank you. I guess the possibilities are endless. I’m just glad no one is mentioning mechanical issues
I cannot imagine any realistic mechanical issue that would cause what you've described.
A bent rim would cause wear on one side of the tire. You have not said whether the wear is even or not, but it seems like you would have said something if the wear ON THE TIRE ITSELF was uneven.
A misaligned axle would cause wear on one edge of the tire. Again, you do not mention anything about uneven wear ON THE TIRE ITSELF.
If you do have uneven wear that was something you should have mentioned at the outset, as that changes the parameters and possible problems.
Really, IMHO, any mechanical issue would cause uneven wear on the tire. Even wear is more likely the tire itself.
Very even wear on that tire. No scalloping.
