al7601
Sep 20, 2016Explorer
universal sealant/caulk?
what should I use to re-apply around outside lights, windows, corners, and anything else outside needing a water tight seal? Hopefully there is something I could use for everything, thank you
For vertical surfaces I use non sag formula ProFlex, for horizontal caulking I use Dicor self leveling lap sealant. If you're going to search out Dicor make sure you understand which version you're buying, and why, as self leveling isn't suitable at all for use on vertical surfaces.
