kearlms
Mar 30, 2018Explorer
Unlevel Fridge
How long can your fridge be off level while in use before it causes permanent damage? I need to park the trailer at the curb and the road is not level. Will it cause much damage if it is out there f...
bobndot wrote:Best post so far. It depends very much on how the fridge is mounted. If mounted against a sidewall (as most are), the out-of-level due to road crown when parking doesn't make much difference (except for stuff falling out when you open the door).
As you stand in front of an rv fridge, the tubes run right to left .
If a fridge is located on a street side or curbside wall its important to have the trailer level front to rear.
