How long can your fridge be off level while in use before it causes permanent damage? I need to park the trailer at the curb and the road is not level. Will it cause much damage if it is out there f...
It was my understanding that out of level causes the accumulation of crystals which block the passage the refrigerant. I am not sure that that is true. But I do know that a three degree tilt is noticeable.
If it worries you I would do as suggested an pull the low side up on blocks.
