kearlms
Mar 30, 2018Explorer
Unlevel Fridge
How long can your fridge be off level while in use before it causes permanent damage? I need to park the trailer at the curb and the road is not level. Will it cause much damage if it is out there f...
otrfun wrote:Hannibal wrote:When you say "shut-off", is it possible your frig overheated and was simply unable to cool?
If my math is correct, our 28' trailer would be 10" higher at one end than the other to be 3°off level. Our fridge has shut off twice while being maybe this much out of lever. Makes wonder if the newer fridges have some protection built in oem.
We operated our previous trailer "somewhat" off-level a few times in the two years we had it. When new it used to regularly cool down to 26-28 degrees with 85 degree ambient temps. After 2 years, it would only do 32-34.
First thing we did with our new Jayco Eagle was install an ARP (and an EMS). Way too easy to forget to turn that frig off---especially when you make frequent rest/scenic stops out-west.
