Hillbilly_Campe
Sep 02, 2015Explorer
@ TusconJim - no we don't have a "Kantleak" panel for water management. Thanks for the reply, though.
@ TUCQUALA - We rarely use the pump, just maybe once or twice a year to winterize and de-winterize. Thanks for the tips, I think you are spot on. Same thing some other buddies have said.
@ CA Traveler and Oasisbob - Once again yes I think that may be a part of the issue. We do ru a pressure regulator though each time. Never hook up without it.
@ Old-Biscuit - That's what I will try, especially if tank starts to slowly fill again on its own. I was always curious why the pump wouldn't run when that happened, but I just quick-checked it without relieving pressure from city water conn. I will turn off outside supply and open the faucet til I get air, then try the pump again. Even if it doesn't refill this trip, I will do that when I get home just to run the pump and try and clean it off a little.
Thanks to all of ya'll again for the tips. Much obliged...
