Keep in mind that with a tuner, you will kiss your factory powertrain warranty goodbye...
Identifying Aftermarket Non-GM Calibrations
For more details, refer to bulletins 08-06-04-033 (Gasoline Engines) and 08-06-04-006A (Diesel Engines).
General Motors is identifying an increasing number of engine, transmission and catalytic converter part failures that are the result of non GM - aftermarket engine and transmission control calibrations being used.
When alteration to the GM released engine or transmission control calibrations occurs, it subjects powertrain and driveline components (engine, transmission, transfer case, driveshaft and rear axle) to stresses that were not tested by General Motors. It is because of these unknown stresses, and the potential to alter reliability, durability and emissions performance, that GM has adopted a policy to cancel any remaining warranty coverage to the powertrain and driveline components, whenever the presence of a non-GM / aftermarket calibration is confirmed -- even if the non-GM control module calibration is subsequently removed.
GM service bulletins 08-06-04-033 and 08-06-04-006 outline procedures to identify the presence of non-GM / aftermarket calibrations. GM recommends performing this check whenever a hard part failure is seen on internal engine or transmission components, or before an engine assembly or transmission assembly is being replaced under warranty. It is also recommended that the engine calibration verification procedure be performed whenever diagnostics indicate that catalytic converter replacement is indicated.
If a non-GM calibration is detected by the dealership, follow the procedures outlined in the bulletin. Once documentation of the non-GM calibration has been received, and verification has taken place through GM, the remaining powertrain and driveline warranty will be canceled.
