fla-gypsy
May 13, 2014Explorer
2012Coleman wrote:OP's Blog wrote:
I’m going to try to keep a fairly clean gray water tank (basically soapy water from sink and shower) so that it does not require a sewer system to be discharged. I do know it's illegal to dump even just a grey water tank outdoors in some states, but I don't think there would be any harm to the environment if I had to dump that soapy water discreetly in a pinch.westend wrote:
As was also noted in your previous thread, here, trying to get around laws dealing with grey water discharge is a recipe for headaches. I wouldn't try it.
You can try to gloss over this part of your plan, but I'd take the advice given by westend. If it was OK to do this, it would never be necessary to do it discreetly.
Now when are you going to actually going to start building?
Just a side note on shower water being clean, I don't think so. If you are human, Fecal Coliform bacteria will be present. You need to rethink the gray water or constantly carry a portable gray water tank to avoid issues with the authorities and other campers.
