myrvplans1
May 15, 2014Explorer
Gdetrailer wrote:
Keep in mind, I am not "defending" what Beemerphile wrote but I do feel there is some very valid points in what was written.
You HAVE been given a lot of extremely useful VALID information from VERY SEASONED and avid RVrs. YOU SHOULD LISTEN UP when someone who has experience tells you something instead of putting your fingers in your ears ..
myrvplans1 writes "You state that I left “out many items that make an RV what it is.” What exactly makes an RV what it is? If I leave out a stove and burners because I don’t cook inside does that make the RV non-functional? Some would say the more you can leave out of an RV the more efficient it becomes (more space, less maintenance, less cost, less weight, etc.) So I don’t think your point on this holds up."
Even though I do not use my stove (which by the way HAS an oven), it IS there none the less just in case the weather outside is way too bad to cook out side. There is no way I would ever want to be forced to cook outside in driving rain, thunderstorm, high winds or even snow.. If that is your cup of tea then that is fine by me..
There ARE some very small trailers which do not have an INSIDE stove/kitchen but those that are like that have it OUTSIDE and it appeal to a small audience, not mainstream RVrs.
To many the whole idea of a RV is to have an all in one "home on wheels", perhaps you care to cite some examples of houses which are built and sold with no kitchen inside or if it has a kitchen it has no stove.
I don't see removing the stove as reducing "maintenance" in fact I don't see anything in your design which has less maintenance than a standard RV.. Doesn't seem to be a valid argument.
More space.. Where? No cabinets = more "space"? I don't see it that way.. Unless you are planning to take one change of clothes, no food, no other earthly goods you will want or need cabinets and or drawers to put those away..
Leaving out the stove does not add space, our stove top has a flip up cover so when not in use we can use it like a counter top or even a desktop workspace..
"Actually... compost, dry toilets, incinerator toilets and a host of other new toilet innovations are a growing segment of the RV industry. Do your homework before you speak. (I did). Even people in high end motor homes are swapping out their black water tank toilets for these other options. A non-black water tank toilet sure has a lot of advantages. Since when does a “portable toilet” make an RV unsaleable? "
I myself have no care or wants to deal with composting, dry toilets or even incinerating toilets. I don't use any of those at my home or even work, why in the world would I want to do that while traveling? I suspect pretty much nearly all RVrs would be in agreement there.
If you like dealing with those types of toilets then go ahead, after all it is your build, but don't expect very much enthusiasm to be present if you want to sell your trailer..
As far as seeing any info about "people in high end motor homes are swapping out their black water tank toilets for these other options." goes, I read a LOT of RV forums besides this one and YOU are the first one I have ever seen mentioning this.. I have my doubts about the validity of that statement. There is very little "advantage" to most RVrs by getting rid of the blackwater tank.
From your statements you don't seem to understand that black water tanks are not any more hassle than the grey water.. In fact black water tnaks tend to fill VERY slowly. A 40 gallon black water tank can take a week or two to fill enough to need dumping, a grey tank can be filled as quick as one day..
Composting, dry and incinerating toilets have a lot of drawbacks and hassles, they have more maintenance and care if you want them to work correctly. The ONLY good thing to them is lack of water usage but RV toilets do not use all that much water, perhaps a quart of water per flush.. The big user of water is SHOWERING/BATHS, not a RV toilet.
Pretty much your design is like tenting but in a hard sided trailer..
Have you actually "camped" in a RV? The things you don't hold dear in your design effort pretty much shows that you never have..
I like my windows, full kitchen (with stove), full operational bathroom including the black tank, pressurized running hot and cold water, cabinets (lots of storage makes for a very neat place), furnace and A/C. It IS my small home on wheels.
GDETRAILER (I think I got most of them...)
“You HAVE been given a lot of extremely useful VALID information from VERY SEASONED and avid RVrs. YOU SHOULD LISTEN UP when someone who has experience tells you something instead of putting your fingers in your ears .”
I appreciate the advice, but you must have also missed my opening post. Please read it again as it reflects I have listened. Yes, some of the suggestions and ideas here have been very helpful. However, while some have not I’m sure they were offered to me with the best of intentions and I am very appreciative that the time was taken to communicate them. Incidentally, one doesn’t need vast experience to offer a useful opinion.
“Even though I do not use my stove (which by the way HAS an oven), it IS there none the less just in case the weather outside is way too bad to cook out side. There is no way I would ever want to be forced to cook outside in driving rain, thunderstorm, high winds or even snow.. If that is your cup of tea then that is fine by me.. There ARE some very small trailers which do not have an INSIDE stove/kitchen but those that are like that have it OUTSIDE and it appeal to a small audience, not mainstream Rvrs.” I don't see removing the stove as reducing "maintenance" in fact I don't see anything in your design which has less maintenance than a standard RV. Doesn't seem to be a valid argument."
Well, I think in a roundabout way you have validated my point. You have a stove/oven which you paid for but you use so infrequently that was it really the best of options to have installed? If it just came with your model then what else did it come with that you don’t use? If I was building a large trailer perhaps installing a stove/oven would not be such a factor, but in a small RV you have to make choices based on need and space. Eliminating the stove/oven does reduce maintenance. We could debate the amount (every bit adds up), but I see a stoves/ovens for their clean up headaches, odors, invitations to bugs, etc. Don’t see anything in my design which has less maintenance than a standard RV? I’m not exactly sure what a “standard RV” is these days, but designing a vehicle without things like slideouts, heating vents in the floor, skylights, cabinetry that collects dust, a shower door, etc. and installing things like a seamless counter top that’s easy to clean will put a little extra time in my day.
"More space.. Where? No cabinets = more "space"? I don't see it that way.. Unless you are planning to take one change of clothes, no food, no other earthly goods you will want or need cabinets and or drawers to put those away."
Yes, there is limited storage space, but it’s only 15' long and I intend to make concessions on what clothes I can bring. That’s just part of the deal in traveling small. With 24 square feet of storage space under the bed, cabinets, a pantry cabinet, overhead cabinets, under floor storage, space in my tow vehicle and a glove compartment... I might have too much storage space.
“Leaving out the stove does not add space, our stove top has a flip up cover so when not in use we can use it like a counter top or even a desktop workspace.”
In a 15' trailer leaving out a stove/oven does allow more space for cabinets and counter top.
“I myself have no care or wants to deal with composting, dry toilets or even incinerating toilets. I don't use any of those at my home or even work, why in the world would I want to do that while traveling? I suspect pretty much nearly all RVrs would be in agreement there. If you like dealing with those types of toilets then go ahead, after all it is your build, but don't expect very much enthusiasm to be present if you want to sell your trailer.”
I thought once as you do now and another forum poster enlightened me. The downside of your toilet parameters is that no matter where you want to go you will always be tethered to a campground, a dump station, using public restrooms or paying for an RV park. Even if you are able to go 2 weeks without dumping that black tank places limitations on where and when you can travel. I traveled that way some years back and it was a nice experience, but now I want a more liberating travel experience.
“As far as seeing any info about "people in high end motor homes are swapping out their black water tank toilets for these other options." goes, I read a LOT of RV forums besides this one and YOU are the first one I have ever seen mentioning this.. I have my doubts about the validity of that statement. There is very little "advantage" to most RVrs by getting rid of the blackwater tank.”
So you read a lot of forums and you haven’t seen ANY info huh? Hold on to your seat. (No pun intended) I just saw this one last night: http://www.gonewiththewynns.com/composting-toilet
and... http://www.gonewiththewynns.com/install-composting-toilet Welcome to the other side :–)
“Pretty much your design is like tenting but in a hard sided trailer.”
Well, okay maybe there is a little truth to that as it doesn’t have every amenity one might have in a larger trailer or a $500k motorhome, but the RV lifestyle is a series of trade-offs. I’ve been able to integrate most of the life sustaining elements (bed, shower, sink, desk, heat, hot water, etc.) into 15' of space. If you can show me a more efficient floor plan within that space limitation I’d pay you very handsomely for it.
“Have you actually "camped" in a RV? The things you don't hold dear in your design effort pretty much shows that you never have.”
Well, I won’t hold your lack of character assessment skills against you. :–) About 8 years ago I bought one of the best TT on the market. A Northwood Arctic Fox - 31 feet...all season, heated tanks blah blah blah. It had every option in it you could possible think of (electric toilet, solar system, and even a 32" Sony flat screen tv which at that time was not offered as an option). It even had a stove/oven too! I also had some professional customization done like replacing the crappy RV bed with a nice residential style bed. I lived in it full time for 3 years. Ever since I bought it I’ve been thinking about how it could be done better. Now, I’m going to do just that. Thank you for your great feedback! -Darla
