myrvplans1
May 18, 2014Explorer
AirForceAngler wrote:myrvplans1 wrote:GrandpaKip wrote:
Darla, I really believe more thought is required of the door situation. Unless there are three locking points on the knob side, you are pretty much guaranteed to have periodic leaks. House doors open inward for security (hinges inside, harder to pry open), ability to easily add screen/storm door, and are not usually trying to resist 60 mph winds. I also looked at reversing the door on my build, but rejected it because of the leak issue. There are ways of mitigating the wind blowing the door upon opening.
[COLOR=]Hey Grandpa, I am putting more thought into the door situation, but I don't yet have enough facts to abandon the idea just yet. Taking the pros-cons of which way a door swings out of the equation for just a moment are rain/leaks really a factor in a door that swings inward? Is there any way to seal such a door from leaks? Are leaks more likely to be an issue in transit or while parked?
I'm just not understanding why leaks would occur in a door that is designed to seal properly. I get really heavy rain on my home front entry door all the time and that thing never leaks. Even when I turn on my lawn sprinklers near my door...never a drop. If this is really an issue then why do you think inward doors are the dominant choice for all these tiny RV homes that are popping up all over the place?
1) Is this an engineering issue?
2) Please share your thoughts on mitigating the wind.
Thanks! Good post. -Darla
What you should do is put in a door that hinges down like a ramp! Then you could just wheel yourself and your ego right up into your box/trailer!
"If being an egomaniac means I believe in what I do and in my art or music, then in that respect you can call me that... I believe in what I do, and I'll say it.” ... John Lennon
