looper's avatar
looper
Update on transmission leak
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29346314/srt/pa/pging/1/page/1.cfm
Thought I would post this follow up to the problem I posted in the above post link.
I took truck to independent transmission shop. Now I am not a mechanic and didn't stay in a Holiday Inn Express last night so I am just passing on what told and the results of the work. This shop and owner have been in business for 40 years and come highly recommended so I felt comfortable with them.
First suggestion from the owner was to sell the Ford and buy a GMC to tow with (joke). He drives and tows with a GMC. He was not sure of the extent of my problem at first but said Ford transmissions are infamous for this kind of leak from the front seal due to the compound of the seal. He said when the seal gets hot it will leak and if you take it to Ford they replace it with the same seal. He was unable to pinpoint any fluid leaking while the trans was still on the truck. He told me if he pulled the transmission and there was fluid in the vent, he would think about replacing the torque converter with a heavier one. If no fluid in the vent, just replace the seal since the fluid was good and had not been overheated while towing. Well there was no fluid in the vent so only the seal was replaced with a new aftermarket seal made of a different compound.
Today I took the trailer out towed it hard for a little over an hour and about 60 miles. When I got home and backed in the drive, where I would normally see fluid leaking, there was not any sign of a leak. I'm keeping my fingers crossed that the seal was the issue.
Two things mentioned here and on another forum were a bigger cooler and chipping the truck. We discussed both those issues and this mechanic said the stock cooler was sufficient and chipping was a great way to burn a transmission up. I don't know but so far the seal has me back towing and camping so I'm hoping this is the end of that issue.
  • sounds good . I,d never chip any truck. if the factory wanted the truck to do beyond its normal range they,d have done it.people chip them then wonder why it broke.
