BurbMan
Jul 01, 2019Explorer III
UPDATE:
Thought I would come back here and close the loop on this. The new Goodyear ST tires are VERY pricey, so I opted for another low-budget set of LT225/75-16E from the local Mavis Tire. The Brand is Taiga, made by Vee Rubber, made in Thailand. Even still it was $600 out the door, about $200 cheaper than a set of the Goodyear Endurance STs.
Taking the old tires off was a real eye opener...I got new rims, so I had the tire shop mount the new tires on the new rims, and put them on the trailer at home. I also replaced the Trail Air equalizers and greased the suspension.
This is what the suspect tire looked like on the trailer:
Once I got it off and put it next to the rear one you get a different view:
Hard to believe these two tires are the same size. The other front tire was starting to do the same which was why I replaced the equalizers, they were worn out and shifting too much of the load to the front axle and overloading the front tires.
I also saw this from my TPMS, where the front tires were running 10* hotter than the rear ones. Now back in business and ready for the next trip!
44,068 PostsLatest Activity: Jun 21, 2026
