BTPO1
Sep 08, 2014Explorer
donn0128 wrote:
What satellite system are you using? Directv has their newest wireless system that only requires cable to the master box. Otherwise i would consider running a new coax under the trailer, being sure to thoroughly seal the holes you drill. I have also had good luck running the coax under or through cabinets to where i want it. Each trailer is unique and does require a lot of thought as to how to get from point A to point B
X2 on running cables through cabinets. I do not like seeing wires so I always find a way to hide them. You can look and see where the original wires are run and can usually follow them. You may have to move a panel or two but it is easy to do. JMO
44,060 PostsLatest Activity: Mar 28, 2026
