352's avatar
352
UPDATE UPDATE
Newly purchased used pop up. AC runs great for about 5 minutes then the breaker flips. 122 volts coming in. Standard OEM cord. Nothing else running. Original AC unit on a 2002. AC cools great for 5 minutes. One split breaker, 15 amp to AC and 20 amp to the rest. 20 amp receptacle service. Breaker feels warm. Bad breaker???? What an I missing? Thanks
The spare 25' cord that was attached to the camper cord was bad at the connection. YEAA. $30 fix. Thanks for the replies.
  • SidecarFlip wrote:
    One thing that most people don't realize is, a thermal breaker has a finite life, IOW, they wear out. Replace the breaker first.
    About 4years old, buddy's breaker acting up and needs replacement.
  • One thing that most people don't realize is, a thermal breaker has a finite life, IOW, they wear out. Replace the breaker first.
  • lenr's avatar
    lenr
    Explorer III
    Sounds like low on Freon. That will cause too much cooling, and then freeze up.
  • A 2002 AC unit, 16 years old, isn’t working or working well, and your question is? Enjoy the five minutes! Or replace the AC.
  • You should post back on your original post on subject!
    https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29559046.cfm
  • Maybe just a loose wire connection at the breaker. Check the screw!
    Otherwise since it gets warm, replace it. they wear out.
