ken56
Feb 02, 2017Explorer
Isn't that the range hood vent? The tabs are to keep it closed when traveling otherwise yes, you are supposed to open them if you intend to use the stove top/oven. My toaster would set off the smoke detector if I didn't run the range hood vent but never did using the stove or oven set off my CO detector if I didn't run the range hood vent. I am not sure your problem is truly solved....future use will tell. How close is the oven to the CO detector? Mine is 10 feet away, so maybe it is a proximity issue. They are quite sensitive.
