blt2ski
Jun 30, 2018Moderator
TurnThePage wrote:
To add another dimension the P vs LT argument, I run all terrain tires due to places we like to camp. P rated all terrains typically have shallower tread depth than LTs. This may have come into play a couple weeks ago where I was barely able to get the trailer out of the campground. I'm considering moving to mud terrains or similar next time, though I don't relish the road noise. Maybe a set of chains are in my future too. :)
Initial depth is one thing......at the end of a tires life, an LT and a P metric still only have a 1/4" of tread or less, so traction is the same!
Have not looked into the XL version tires, but at one time, I believe it is still truck, you need to derate a P metric when used in a truck or trailer application by 9% of the sidewall load ratings. Then again, LT tires, not sure about P metric, when used at speeds under 25mph, you can increase the sidewall amount by 50%!
Reality is, there is NO BEST tire brand or tread. Only what really works BEST FOR YOU! I know folks that swear by Michelin EPS ribs......you could not give me a set! UNLESS, it was a rwd rig, put ONLY on the front steer tire, and I had some EDE M+S or the most recent variation of it on the rear.
At the end of the day, make sure the rubber is round! Otherwise, you will not like how things handle......
Marty
44,056 PostsLatest Activity: Jan 12, 2020
