deltabravo
May 30, 2017Nomad
Lots of jackstands and lots of jacks are needed. 4 of each.
4 jacks were needed because the center of gravity on torsion axles is close to the brake drum. If you lift/lower the axle under the jack tube, the axle will try to fall off the jack by rotating towards the heavy side, the brake drums!
