Westcoasting
Feb 19, 2016Explorer
Upgrading axles
I have a 22' arctic fox and I want to upgrade the axles to go from 15" tires to 16" tires. Any advice or guidance on how to proceed is greatly appreciated. My current wheels are 5 x 4.5 x15".
gmw photos wrote:
if you have adequate axles ( my bet is it has 3500 pound axles ) and are simply wanting to go to a tire that has adequate load capacity and a higher speed rating, then an example would be to switch to goodyear cargo g26. In a 225-15, they have 2470 lb. capacity. So that is nearly 10,000 pounds of load capacity under a trailer with what, about 6000 pounds sitting on the axles, all loaded to go ( isn't your trailer about 7000 GVWR ) ??
Westcoasting wrote:Good choice. Once you go to 16s you won't ever regret it.gmw photos wrote:
I have seen those tires online but I can't source them in Canada so I've decided to go with an axle flip and 16" tires. Right now I'm running Goodyear wrangler ht with no issues. Do a lot of off road camping so the extra clearance will be nice.
Westcoasting wrote:Dexter says 1" between the tires.
I will check that out, thank you!
Huntindog wrote:Westcoasting wrote:Dexter says 1" between the tires.
Since you presently have 15s, it is a pretty safe bet that you have the room.
The TT that I first put 16s on started life with 14s. That was real close, but it worked out fine.
Terryallan wrote:
Only question I have. Do you have room between the tires to go a sixe larger? Mine are pretty close together now. closer together would create more heat, and might increase the chance of failure.
