drcook wrote:
Also if buying a used diesel, be skeptical of:
2004.5 and 2005 GM/Chevy Duramaxes. Engine RPO code LLY
They have overheat issues and head gasket issues. A blown head gasket's price tag at the dealership is 4000.00 to 5000.00. It is 600 to a grand and a week's worth of work to do it yourself. I cured my overheating issue with an extra radiator and larger trans cooler, plus a GM installed '06 airbox and other changes. We got the truck for $10,000 of sticker so I am OK with my fixes, but I am making sure I don't do anything to blow the HG's. Unfortunately, due to a design issue that was subsequently changed, it is probably inevitable.
You didn't consider the Killer Bee fix with bigger turbo inlet?
I've not had the problem (knock wood) towing my small 10k 5th wheel.
Why did you go to a larger transmission cooler?
