beemerphile1
Sep 11, 2014Explorer
It is easy to see the reason for the metal. I did the same thing to my pop up.
First off, that is a terrible installation as refrigerators in slides usually are. The upper vent is nowhere near high enough.
The sheet metal is an attempt to correct the bad installation. Its intention is to prevent the air flow from exiting under the tube you see just above the metal. By partly blocking the opening the air flow will go higher past the tube.
The visible tube is where the ammonia vapor is condensed to liquid. More airflow equals more liquid. More liquid equals better cooling.
