scbwr's avatar
scbwr
Explorer II
Mar 27, 2016
Use a 50 amp adapter instead of 30 amp service?
We're at a RV park near Jekyll Island, GA and as usual, for our 30 amp travel trailer, we were plugged into the 30 amp outlet with our Progressive Industries PT30C in use. The breaker tripped and we were in the dark. I went out to the power post and could not get the 30 amp breaker to reset, so I got out my 50 amp adapter and that solved the problem. At the time of the breaker tripping, the AC was running and the electric hot water heater was on and heating after I took a shower.
The following morning, I went to the office and ended up speaking with the owner. He came over, and was able to reset the breaker...I wasn't using enough pressure to force the breaker to reset. But, here is where my question evolves. He said that the newer 30 amp breakers that he is required to use by law tend to trip much more easily than the older breakers and he said that because of that, it is better to always use the 50 amp adapter. Does anyone have any experience or comments about this advice?? I know the adapter simply draws power on only one of the spades, so I don't see any reason not to use the adapter, but just wondering if anyone else has received this advice or uses the 50 amp adpater rather than plugging into the 30 amp service.:@
  • When running the A/C put the WH on propane. Regardless of whether using the 30 or 50 amp receptacle.
  • Whenever 50 amp is available I use the dog bone and use the 50 amp. If only 30 amp is available I sometimes have no issues but sometimes it will trip. If it trips I put the water heater on gas.
  • What do you do in campgrounds where they have an additional charge for 50A service? Do you pay the charge or just use the 50 without paying or do you ask first?
    If you use it without paying, wouldn't that be akin to stealing?
    I never ran into a camptground that has both on the same spot, but has an upcharge for 50a. Having said that, a state park I was recently at had two different types of spots, one with 50a, and others with 30a. It was cheaper for the 30a spots but those didn't have 50a as an option.
    Mike
    The few campgrounds that I have stayed at that charged extra for 50A service charged more for the site with 50A service. So you paid the additional fee up front whether you used the 50A service or not.
    Just what Mike posted while I was typing.
    My trailer is not a 50A trailer. So I don't worry about it.
  • If you pay for a 50 amp site then you can use it. If you do not pay for a 50 amp site then you don't have it available at the site.
  • Most of the campgrounds I go to usually have both available on the pedestal. The pedestal looks like the picture posted on page one of this thread.
    Isn't the upcharge for the use of the 50A service? I didn't think it had anything to do with what your trailer uses. Depending on the time of the year I my trailer might only use 10 amps.
  • Again, thanks for all the responses.
    Just a couple of points:
    1. Local codes can dictate the type of breaker used.
    2. I've been plugged into 30 amp service many times and have had the electric HWH running along with the AC and haven't tripped circuits. Now, if the breaker had reset, I would have flipped the water heater to propane.
    3. I tried resetting the breaker without any load at all, i.e. I disconnected the PI EMS. The owner had to press very firmly at the off position of the breaker, and then it did reset. Is the breaker faulty....I don't know.
    Now, if I'm plugged in with the 50amp adapter, and the PG EMS is plugged into the power post (it's the portable model), I would think that if there was a short and 50 amps was sent to the PI EMS, the EMS would do it's job. That being the case, I don't see any danger in using the adapter! Any comments??
