turbojimmy
Jul 19, 2016Explorer
S.K. wrote:beemerphile1 wrote:
Just make sure that you dump into a sanitary line and not a storm line. Other than that, no worries.
How does one distinguish the two? Do they use the same type of caps?
In my case the caps were identical. I opened one up thinking it was a sewer and I could see it was a dry well (a pit full of stones). I opened up 2 others farther upstream that appeared to be on the same run. One was another dry well the other was a cleanout. All 3 were for rain water management - NOT sewer. When I looked inside the cleanout it could easily have been mistaken for a sewer.
I ultimately did find the correct sewer cleanout in my yard. Visually it looked like it could be on the same run as the storm water management but it wasn't. A sure way to tell is to open up what you suspect is your sewer cleanout and have someone flush while you shine a flashlight down in there and/or listen for running water.
