jaycocreek
Jul 17, 2018Explorer II
The funny thing about this thread and deaths incurred via placing a honda gen set in an existing/sealed gen compartment with an exhaust extension is nill/none..I could not find one in a google search caused by this mod..
There are plenty of them from a built in generator such as the Onan or a neighbors gen set fumes but none I can find from a portable in the sealed gen compartment.And yes many from the Darwin clan succumbed to generator fumes.
There are so many other things in an RV that kills beside generator fumes that really never get attention but somehow this mod scares some even if done properly.
I still maintain that built in Onan generators are a greater threat to life than one an RV guru would put it because of the exhaust fumes and where the Onan tail pipe exits the fumes...
One little wind change and good night Charlie.
In RV’s, carbon monoxide gas usually results from:
• Exhaust leaks from a vehicle engine or a generator
• Improper use of portable gas powered heaters
• Someone else’s vehicle or generator when camping in close quarters
• Malfunctioning or unvented LP gas appliances
If your RV doesn’t have a carbon monoxide detector you need to purchase a battery operated carbon monoxide detector designed for use in RVs. Test the carbon monoxide detector every time you use the RV, and replace the batteries when you change clocks for daylight savings time.
Other Tips
• Inspect the generator exhaust system before using the generator, every time
• Avoid leaving windows down and roof vents open when in close proximity to vehicle and/or generator exhaust
• Follow all directions and safety cautions and warnings when operating gas powered heaters
• If you use a portable generator direct the exhaust away from the camping area
• Never use the range burners or oven to heat the RV!
• When cooking with the range burners use the range fan and always leave a window cracked open for fresh air and ventilation
