- OasisbobExplorerSorry not a good idea as some exposed lines & drains may still freeze in adition to water heater. I blow air through lines, anti freeze in drains and still run small heater on timer to keep canned food from freezing
- Dennis_M_MExplorerPersonally I would never leave an unattended electric heater running in my RV at anytime. Winterizing take me about 15 minutes, then no worries at all.
- punomaticExplorerIn the days when I had a boat moored on the Columbia River, I used a couple of strategically placed heat lamps to prevent freezing. Never had a problem, even during a couple of years that the Columbia froze deep enough that I could walk around the boat on the ice.
- TrackrigExplorer IIThe heater will help with the humidity, but the heat won't get down to the bottom of the tanks or some other places that could freeze such as your drain valves.
Bill - 3oaksExplorerMay work ok providing you don't have any prolonged power outages.
I would prefer to winterize using RV anti-freeze. - WNYBobExplorerIf you do use a portable heater, put a remote reading thermometer in the camper to verify the temperature inside. It's cheap insurance. I would keep it above 40° to make sure the lines near the floor or walls are not below freezing.
- 2oldmanExplorer III would use one only if:
- I'm around to check it almost daily
- I'm taking camping trips in winter and need the coach to be ready to use
- There's enough heat to protect all the lines (unlikely) and the power it draws doesn't heat up any extension cords (likely)
- I've drained the lines - Turtle_n_PeepsExplorerI would have no problem using them. Just set it on a real low stat setting and call it good. I use light bulbs and heat tape to prevent my stick and brick from freezing so I see no problem with a modern heater.
- Old-BiscuitExplorer IIIWinterize it.......only takes minutes and works
Portable heater.......
power outage/no heat
tripped breaker/no heat
doesn't fully circulate heat thru out trailer
uses power unnecessarily
Winterize it....... - GordonThreeExplorerair and antifreeze are your best defense against freezing. Heaters like to stop working, or sometimes they work too well and burn things down.
If you want to avoid winterizing, look for heated indoor storage.
44,052 PostsLatest Activity: Oct 29, 2025
