hanklee2016 wrote:
#1nobby wrote:
People....it's an $800 32 year old trailer.
It's worth $800 even if NONE of the appliances work.
Check the tires and valve stems for cracking....put the appropriate amount of air in them....make sure you have a serviceable spare.
Check the exterior lighting system when hooked up to your truck.
If you are not sure....check / re-pack the bearings.
Enjoy the trailer.....your truck should be fine. :)
$600 makes it even better deal! HAHAH.
Yup, Buy it. If you are close to me and you do not want it I will find someone that does.
If all else fails you can tear it apart and use the frame for a
trailer.
But, I'm a Caveman that lives in the country and I can do stuff like that.
For 600 bucks I think you should take the risk. If it looks like there are no leaks and everything is not rotten it is probably good enough for what you want to do.
I do agree that you should put on new tires. Go to you local automotive repair shop;; that you trust;; and price them out. They should not be that expensive.
