MFL
Jun 08, 2023Nomad II
OP..Yes, the Ford FW prep package is a bargain. Not buying the adapter, will be getting this package for free. You will also save the time, or money, to have rails installed, as you can just set the puck ready hitch in, lock the handles, and done (a 5-10 minute install).
I'll add a pic, showing the puck attachment points on hitch, and handles that just turn to install, turn to lock it in.
You may need to increase pic size to see the attachment points more clearly.
This hitch for OEM Ford pucks, separates easily to two pieces. the head weighs 75 lbs, and the base 78 lbs. Very easily managed, but super solid build, with zero slop in the pucks.
Jerry
Jerry
