ZagiFlyer's avatar
ZagiFlyer
Usefulness of Ford "5th-Wheel/Gooseneck" package
I'm looking to buy a Ford F250/350 as a tow vehicle for my next 5r. I already have a Reese sliding 16K hitch from my previous 5r (Part No. 30051). I also see that Ford OEMs hitches. My question is, if I get the 5th-Wheel/Gooseneck package on the truck, will the Reese slider that I already have fit in the slots Ford puts in the bed for this? The Reese installation manual seems pretty specific on the distance between front and rear mounting plates, etc. I don't want to go out of my way to get this option if the holes they put in the bed aren't usable for the Reese 16K sliding hitch.
I know I can just get the truck without the package do an aftermarket install, but the cross-member they add, along with prewiring the pigtail seem worth it -- but only if everything lines up.
  • BB_TX wrote:
    If you plan to keep the truck for a long time get the hitch package. You may someday decide to try a different hitch that would use the puck mounting system. Or even the Goosebox gooseneck adapter that is growing rapidly in popularity and use the ball mount.
    Thats what I got from Curt. I really like it.
  • If you plan to keep the truck for a long time get the hitch package. You may someday decide to try a different hitch that would use the puck mounting system. Or even the Goosebox gooseneck adapter that is growing rapidly in popularity and use the ball mount.
  • Your existing hitch will only fit in the OEM puck system (they're not slots) if it is designed for the Ford OEM puck system. I would also not recommend the Ford-branded hitch. I have - and really like - an OEM puck system equipped truck and really like it. I use a PullRite hitch designed for the Ford puck system.
    Rob
