RoyB
Feb 23, 2015Explorer III
What we do is run all the 120VAC items we want to run from the inverter which is connected to a calculated battery bank and all of the 12VDC items connected directly to the batteries.
Where we camp has generator run time restrictions in place so we run off the batteries and hopefully don't drop our charge state below 50% before 8AM the next morning when we can run our generator.
The only reason for the generator is to re-charge the battery bank in as quick of a time frame as possible. The only reason for the solar panels is help re-charge the batteries so we don't have to run the generator as much.
This is what we would have to do here on the East side of the USA when camping off the power grid where the campgrounds usually have generator run time restrictions.
The 3000W INVERTER will require a very large battery bank if you are planning on loading it down full load. This would be pulling 250 AMPS DC current plus losses from your battery bank if fully loaded down. That is alot of juice to pull...
Your solar panels would have to produce a very large amount of DC current to run directly off the panels. The only good use for using the solar panels is to help charge the batteries during the HIGH SUN time of the day. A typical 120W SOLAR panel will only produce around 5 AMPS DC current when in high sun. High sun is usually only 5-6 hours a day...
Need to do some good planning on what you want to do with your setup and beef up things accordingly...
Just my thoughts...
Roy Ken
Just my thoughts...
Roy Ken
44,066 PostsLatest Activity: Jul 25, 2018
