ssthrd
Feb 16, 2023Explorer
IMHO.......... If you look at the "bumper" on your TT, you will see that at best it will store your stinky slinky, and not much more. The static load on the very thin tube is one thing but the forces generated by a 200/300 pound lever bouncing up and down will be much more. I think that most here will agree that it's not a good idea.
I carried my spare tire that way for a year or so, but the load was vertical and didn't bounce around as would a relatively heavy basket extending a couple of feet behind the trailer.
You see them on the road, but given enough time, they will probably fail. Maybe at the next railway crossing or the frost heave that snuck up on you. Not to mention the transition from the street to a steep driveway where the basket scrapes the ground because of the extended overhang. Lots of scenarios.
If you go to a welding shop, they can attach a hitch directly to the frame, and you can mount the basket on that.
