BackOfThePack
Mar 02, 2023Explorer
It’s a bad idea in all ways.
200# far from the axle centerline “weighs more” given tail-whip (centrifugal force). Shortens the already too-short amount of time to correct trailer sway (a few seconds in best conditions). That, alone, mitigates against it.
Second, it tends to either cover or obstruct trailer brake/turn/warning lights. From several angles. Again, this ALONE mitigates against it.
Third, backing is more difficult as this increases the amount of “trailer swing”. AND one can’t see the edge leading as one backs (I do this for a living: the joke about truck drivers is that they don’t pay us to drive them somewhere, they pay is TO BACK THEM as the vast majority of truck-caused property damage is while backing). Lose any idea you can avoid backing.
Fourth, and potentially the most serious, is related to number one in that one has lengthened the sail area against a crosswind.
Winds are the TT problem. “Vision” by operator and others is hampered. (We can find more).
To go camping means toss some clothes, food and beer into trailer. I believe you need to clean it out (100%) and start over in packing what you actually use. We all go thru the pains of adding too much and having to remove the “what if & just-in-case” stuff.
Make going camping simpler. If you do, you’ll go more often. (Bank on it)
