Grit_dog
Mar 02, 2023Trailblazer
BackOfThePack wrote:
It’s a bad idea in all ways.
200# far from the axle centerline “weighs more” given tail-whip (centrifugal force). Shortens the already too-short amount of time to correct trailer sway (a few seconds in best conditions). That, alone, mitigates against it.
Second, it tends to either cover or obstruct trailer brake/turn/warning lights. From several angles. Again, this ALONE mitigates against it.
Third, backing is more difficult as this increases the amount of “trailer swing”. AND one can’t see the edge leading as one backs (I do this for a living: the joke about truck drivers is that they don’t pay us to drive them somewhere, they pay is TO BACK THEM as the vast majority of truck-caused property damage is while backing). Lose any idea you can avoid backing.
Fourth, and potentially the most serious, is related to number one in that one has lengthened the sail area against a crosswind.
Winds are the TT problem. “Vision” by operator and others is hampered. (We can find more).
To go camping means toss some clothes, food and beer into trailer. I believe you need to clean it out (100%) and start over in packing what you actually use. We all go thru the pains of adding too much and having to remove the “what if & just-in-case” stuff.
Make going camping simpler. If you do, you’ll go more often. (Bank on it)
Roflmmfo!
Where to start …
1. Yes or maybe but not necessarily. Especially since you have no idea how much weight the OP was thinkin about hauling back there or the trailer weight/tongue weight.
2. Nope not even close. Google a hitch rack and then go measure the spread between your tail lights… duhhh
3. Nope again, refer to #2. Width. Maaaaybe in a perfect 90 deg ijackinife with virtually zero extra clearance. But by then if you don’t have a spotter, a camera or legs, to get out and check, you’ll probably smash the corner of the trailer first.
4. Lol. This is perhaps the funniest, biggest stretch to try to sound smart. Exactly how much “sail area” is added with a little piece of angle iron and some firewood/genny and gas can, mother in laws suitcase, you know the typical stuff that goes on a light duty hitch carrier?
5. Now you’re just trying to hard to create text.
6. No one cares how “you” camp, nor is it polite to presume a whole bunch of stuff about someone else because you conjured up an image or opinion.
If you’d have stopped after “bad idea” (generally, due to the lightweight construction of camper bumpers) you would have had a lucid response.
Cheers slowmover!
