drumming102's avatar
drumming102
Using the slides while retracted
We have a 2015 passport 2920BH with a jacknife and U dinette on a slide. Are you able to sit on the sofa or use the dinette while retracted? I have shyed away from it because it feels like the slide flexes when you step on it while its retracted and it feels like you might break something if you put your full weight on it.
  • drumming102 wrote:
    ....it feels like the slide flexes when you step on it while its retracted and it feels like you might break something if you put your full weight on it.
    You answered your own question.
  • Does your slide tilt up when retracted vs laying completely flat on floor?
    Tilts up....no support under slide floor so NO don't step on it, walk on it, get inside slide etc when retracted.
    Floor and consequently the whole slide is not supported unless extended.Then it becomes a fully supported unit
    If slide moves in/out flat on top of trailer floor then it is self supporting when in or out like a bedroom slide with bed
