westend
Dec 17, 2013Explorer
USMCRet93 wrote:Ho,ho.ho... I hope the elves are still packing the sleigh, I need one of those coffee makers. If I have company, I boil water and let drip through a funnel. If it's just me, I use a percolator or even drink it "cowboy" style.Chuck_thehammer wrote:
at idle most charging systems can only produce 30 percent Max. you are mostly using the battery in the truck to run your coffee pot.
if you could run the truck engine at 1,500 to 2,000 then you would be charging your trailer batteries.
You could try a Coleman Camping Coffee pot...
Coleman Camping Coffee Pot
It works very well on my stovetop.
Battery charge time calculator Approximate times, don't think it's set in stone. As the battery is charged, it will accept less current so the duration will be longer to 100% SOC.
44,066 PostsLatest Activity: Jul 25, 2018
