tenbear
Dec 18, 2013Explorer
IMHO the biggest problem in using the truck alternator to charge the trailer batteries is the wiring between the truck and trailer. Unless things have changed since I had a trailer, the trailer wiring, and maybe the truck wiring too, is to small to carry the current that a discharged battery requires. There will be a large voltage drop which will result in a very slow charge.
As you say, jumper cables work fine if you keep the RPMs up.
44,066 PostsLatest Activity: Jul 25, 2018
