Hybridhunter
May 08, 2014Explorer
pianotuna wrote:
Hi Hybridhunter,
What inverter were you using? Thanks in advance.Hybridhunter wrote:
The alternator has such high output at low rpm, I was able to run our window AC off of it (via our hard wired inverter)all night, burning about 2ltrs an hour of fuel.
Hmmm. I believe it's a Xantrex MSW 1500watter? Not positive on that though. Hardwired, and due to a design overhaul, its 12'from the battery bank. Wired with parallel 2ga I believe.
In the Toyota, we ran the OEM inverter, and plugged in the (different camper) OEM converter. That was a slick setup, just plug and play.
(Otherwise the Tacoma was a terrible all around vehicle)
44,066 PostsLatest Activity: Jul 25, 2018
