ticki2 wrote:
ticki2 wrote:
It will depend on how the flatbed is made , there are several types . On mine it has 3" I beam cross members and 1/8" diamond plate on top . I mounted 1/2" ss D rings at the 4 corner with reinforcing under the I beams spaning at least 2 cross members . For turnbuckles I used 4 short spring loaded Anchor Guards from torklift . Be sure to use a barrier between the ss and aluminum . This has worked for me for 10 years with no damage to bed or TC . Good luck and enjoy all that extra storage .This may work with a Utility Bed depending if their is enough room to get your hand in to tighten .
I assume you are referring to just mounting to a flatbed, Yes, the anchor points you discuss would work perfectly. I am more interested on how to anchor a TC when it is sitting inside a utility truck bed with service sides. I’ve seen TC’s in them, but now how they are fastened to them.....
