rhagfo
Dec 31, 2014Explorer III
ScottG wrote:
Unfortunately these days the dual disk clutches fail mechanically before they wear out. And doing so at about 70~100K is normal.
If a DD clutch starts acting up on you, get it fixed fast. Otherwise they can do a lot of very expensive damage.
I put a DD organic behind my 01 Cummins and could not be happier! Can be a little grabby, but not very often. No more effort to depress the peddle than standard clutch! There is no reason that V10 can't make good use of a good DD clutch, South Bend makes a very good clutch. I run a Valair also a good clutch might check with both. The DD are not cheap, but will hold the tourqe of your V10.
