jerem0621
Nov 30, 2013Explorer II
If you are OBDII then you have a DPEF sensor and they go bad and do exactly what you are describing. I have also had a lot of mod motors and the cop/spark plug miss tends to appear around 2000-3000 rpm at light load. (Mostly in third gear)
The lighter miss off idle has always indicated a DEPF failure in my experience with three different mod motors.
If it's the DEPF it will throw a CEL before long. Mine also proceeded a 100% catalytic converter failure on a 5.4. (that was FUN)
Good luck.
Jeremiah
Good luck.
Jeremiah
