sllims wrote:
Thanks handye9, interesting concept. So, you need to raise the TT/TV when you tighten the chains?
Pretty much the same as with other hitches.
Step 1.
Trunion bar hitch - Lower the trailer coupler onto the ball and latch the coupler.
Andersen hitch - Lower the trailer coupler onto the ball and latch the coupler.
Step 2.
Trunion bar hitch - Use tongue jack to (lift) reduce weight on the coupler / ball.
Andersen hitch - Use tongue jack to (lift) reduce weight on the coupler / ball.
Step 3.
Trunion bar hitch - Hook chains into snap up brackets and use the bar to pull them into position.
Andersen hitch - Insert chain ends into the brackets (under "A" frame) and tighten the compression nuts. The hitch comes with a 1/2 inch drive socket, you add the ratchet or breaker bar. Easiiest with a long handled ratchet.
Step 4.
Trunion bar hitch - Crank tongue jack into travel position. If there is additional anti sway equipment, add it now.
Andersen hitch - Crank tongue jack into travel position.
Step 5.
Hook up safety chains and break away cable. Same for both.
Only differences are step 3 and anti sway part of step 4.
