sllims's avatar
sllims
V-Front Trailer & Chain Hangers
I am a newby and just bought a V-Cross TT. I like the Strait-Line Dual cam hitch and see they have a bolt-on and clamp on chain hanger available for V-front models. I was told that yo need to jack up TT and TV in order to hook the chain on the hanger. Does anyone have experience with this? How practical is the to do. It makes sense to me but I'm wondering if there are any problems or difficulties in doing this. Thanks
  • As others have said, this is very common and typical with any weight distribution hitches.
  • BTW when they say "lift" it doesn't mean lift the tow vehicle off the ground. It's just taking some tongue weight off to make it easier to hook the weight bars.
  • Drew_K wrote:
    It's no big deal. You use your trailer tongue jack to lift up the truck and trailer. Basically, put your trailer on the tow ball, latch them together using the coupler lock, then use the trailer tongue jack to lift. It'll lift both the TV and TT since they're coupled together now. This job is even easier if you have an electric tongue jack.
    Yep, good answer.
    Coupler locked on ball and lift with the tongue jack. Electric makes it easier.
    OP will find the same is true with all weight distribution hitches.
  • It's no big deal. You use your trailer tongue jack to lift up the truck and trailer. Basically, put your trailer on the tow ball, latch them together using the coupler lock, then use the trailer tongue jack to lift. It'll lift both the TV and TT since they're coupled together now. This job is even easier if you have an electric tongue jack.
