- ognendExplorer II
Cummins12V98 wrote:
This is what I use. Just aired up today for the trip North tomorrow. EEZ-PEE-ZEE.
Last pic, love the screw on caps with check valve.
Much obliged, Sir! - fj12ryderExplorer IIII don't have those screw-on thingies, but that is exactly the chuck I use on my dually. Makes a pretty easy job out of it. I just have to find the darned things first, but after that no issues. :)
- Cummins12V98Explorer IIIOPPS
- Cummins12V98Explorer IIIThis is what I use. Just aired up today for the trip North tomorrow. EEZ-PEE-ZEE.
blofgren wrote:
Cummins12V98 wrote:
Owned a RAM Dually since 2012. I have the stock valve stems and see no reason to add extenders!!!
Use the proper double ended air chuck and life is GOLDEN.
X2. I just ensure that the inner stem is accessible through a hole on the outer wheels when installing them. I usually put them at 180 degrees from the outers to keep them consistent on both sides and they are easy to check. My Ram also has the "valve caps" on the inners where I don't need to remove the caps to check pressure or add air; just stick the gauge or chuck on and all is good. It really isn't difficult to do if they are installed correctly.
Discount Tire "Usually" gets the 180 offset correct but once it was a real struggle to get the guy to comprehend the logic!. - JRscoobyExplorer II
ognend wrote:
fj12ryder wrote:
You probably don't need to buy another compressor. The chuck most likely just screws on and you can buy an adapter from any decent hardware store that will allow you to change chucks easily for less than $20.
Thanks. I will try that first.
1 of my hoses had the chuck molded to the hose. Few seconds with sharp knife had the chuck off. Trip to plumbing supply store, (hardware store would of had it but I prefer to walk a few blocks instead of driving to other side of town) picked up barbed fitting to screw chuck to.
When I'm shopping for chuck, I look in the end. Best if it has small groves inside. Look like threads, except oversize and not spiral. With those groves you can push it on the valve stem and the weight of it will hold it on. Big tires/small pumps, this is important. - ognendExplorer II
fj12ryder wrote:
ognend wrote:
You probably don't need to buy another compressor. The chuck most likely just screws on and you can buy an adapter from any decent hardware store that will allow you to change chucks easily for less than $20.fj12ryder wrote:
Carry your own air compressor with the ability to change chucks. Not that expensive and it keeps you from being at the mercy of whatever air compressors you can find. A hundred dollars or so for your own compressor is chump change considering what you have.
I do carry it but I don't think it will accept different chucks. I agree with you - will just buy a proper portable compressor that does. Thanks! :)
Thanks. I will try that first. - fj12ryderExplorer III
I do carry it but I don't think it will accept different chucks. I agree with you - will just buy a proper portable compressor that does. Thanks! :) - ognendExplorer II
JRscooby wrote:
ognend wrote:
The problem is - I have a portable compressor (the kind that connects to tow vehicle battery) - and that one does not really accept different chucks etc. Also, how is a long chuck going to help me if I have to air my tires at a gas station while traveling? Unless I am not understanding something here...(there might be a language barrier, I live in the States but am not American by birth so not sure if I understand what a "chuck" is). Thanks.
I call the piece that attaches to end of hose, locks on valve stem the "Chuck"
Now as for the "not really accept". I have that kind of compressor in pickup and DW's car. But mine where made by man, not created by a god. When I tested both would pop off as soon as I let go of it. Man made it, I paid for it, so I have no issues changing it. (I don't use a quick-couple, only because I only use for tires. I want the chuck to be on hose so don't want to look for it.
As for air at gas stations; In the area you travel will the station compressor work when you need it? And if it works, will it put out enough pressure to air your tires? And do it without overheating/shutting down? (I have tried to use them on bicycle tires. Success was limited to the point I carry a hand pump now). If your tire takes 50PSI and pump maxis out at 60, it will take a long time to inflate tire. Plus the issue, you drove to station on under-inflated tire, so no longer cold. What pressure you set it to?
Thank you for taking the time to explain. I am a fluent English speaker but sometimes uncertain of "technical" terms :)
When hauling my truck camper on the flatbed (and I always have the horse trailer in tow with the camper since we camp with our horses only) - my rears are at max pressure - 80psi - I am almost at GVWR for my vehicle fully loaded/hooked up. As you suggest - I think what I am going to do is get a proper portable compressor to take with us - one that accepts different chucks :).
Thank you!
44,070 PostsLatest Activity: Sep 18, 2026
