blofgren
Apr 28, 2023Explorer
Cummins12V98 wrote:
Owned a RAM Dually since 2012. I have the stock valve stems and see no reason to add extenders!!!
Use the proper double ended air chuck and life is GOLDEN.
X2. I just ensure that the inner stem is accessible through a hole on the outer wheels when installing them. I usually put them at 180 degrees from the outers to keep them consistent on both sides and they are easy to check. My Ram also has the "valve caps" on the inners where I don't need to remove the caps to check pressure or add air; just stick the gauge or chuck on and all is good. It really isn't difficult to do if they are installed correctly.
