NJRVer
Mar 05, 2020Explorer
klr650goldwing wrote:
Okay, I purchased the correct chuck and I can see how it WILL work to air up both inner and outer tire on the rear. However, I can't get my hand in to remove the valve stem cover. I tried a needle-nose plier, a regular plier and neither would do the job. Is there a special tool for this task or do you have a very small hand available to help out? How do you remove the valve stem cover on the inner dually?
I found on my Ram it's easier to reach behind the outer dually between the two tires to get the cap off than to try and get it off through the hole in the outer rim.
