fj12ryder
Mar 05, 2020Explorer III
klr650goldwing wrote:I use a piece of flexible clear tubing just big enough to be a snug fit around the valve stem cap. I simply push the tube onto the cap and unscrew it, and vice versa when putting it back on. Works a treat.
Okay, I purchased the correct chuck and I can see how it WILL work to air up both inner and outer tire on the rear. However, I can't get my hand in to remove the valve stem cover. I tried a needle-nose plier, a regular plier and neither would do the job. Is there a special tool for this task or do you have a very small hand available to help out? How do you remove the valve stem cover on the inner dually?
