Huntindog
Mar 10, 2020Explorer
Cummins12V98 wrote:More likely it is Arizona heat.Huntindog wrote:Super_Dave wrote:
One of the biggest problems that I have wrestled with is tire shop techs being smart enough to offset the inner tire so that you can reach the stem through the wheel. I don't leave the tire shop anymore without checking to make sure they aligned them correctly and didn't put a standard plastic stem cap on them.
X2
Also I found some metal valve stem caps that allow one to air thru them. The plastic ones break pretty fast.
5 years and zero issue with the non cap valves on my DRW. Maybe after market are the bad ones?
Nothing rusts here. But plastic goes downhill quickly.
The metal ones I got are pretty nice. I think they are stainless. They do allow quite a bit of leeway in lining up the chuck
