klr650goldwing's avatar
Mar 04, 2020
Valve stem extensions for DRW
Has anyone put valve stem extensions on their DRW? We recently purchased a dually truck and I can't air up the inner dually on either side. I'm thinking of doing something to make this easier. What is your solution?
  • Milton Industries S-690 Single Milton 1/4" Fnpt Dual Head Air Chuck AMAZON
  • Never used on in 30 years of owning a dually! Correct chuck and filling inner tire, checking pressure is a piece of cake!
    Incorrect chuck or pressure guage, and yes, you have problems all around.
    Prefer to get rims with bigger holes to get to valve stems if correct chuck etc is not available.
    marty
  • Try the extended valve stems from Your Tireshop Supply I use them on my duallys,makes checking the air pressure fast and easy.
    You do not want those braided extensions,a solid valve stem is the way to go.
