I don't intend to be a forum faux pas but
If you have dimming lights then you have wiring issues, or battery problems.
If this is your reason then it might be cheaper to fix the needed-to-be fixed issues with the wiring instead.
Surflo pumps have a pressure screw on the end, the bullet shaped plastic end, right in the center where you can adjust the pressure. (I lower mine to help conserve water). A phillips head driver will easily adjust it. I am not sure this is your goal.
Sometime the noise is from the rigid pipes resonating through the camper. You can add in flexible hoses (like ones to a toilet or sink in a house) at both sides intake and output of pump which will greatly reduce the amplification of the motor noise. Homedepot has lots of these.
It might be that your wire is too thin to the pump, the 12v+ feed to the fuse box, a bad ground or something somewhere in the electrical system and that is why the lights dim. You really should not notice the lights dimming so much from a pump. Though, I have two batteries, so one battery, or a small battery, or a weak battery might let lights dim more.
Something to consider…
