KFCCaravan
Oct 06, 2014Explorer
I don't have my owners manual handy but a quick google seems to indicate the WK2 Grand Cherokees have a trailer frontal area limitation of 55 sq-ft - not 32. The Travel Lite i18 seems like it would have a frontal area less than that. Also, if your G.C. has the tow package, you should be legal to tow 6200lbs (not that I'd recommend that).
This trailer looks a like a really good match for the Grand Cherokee. I pull a trailer with very similar specifications with 2014 Grand Cherokee V8 and it is a joy to tow. The rig is rock solid with weight distribution and no sway control. MPG is not great but better than most gassers. I get between 10-13 mpg depending on my speed. The only thing I cannot speak to is how the V6 will perform. I think it would be adequate but be ready for sustained high rpm operation on any kind of a grade.
The 8 speed transmission really shines when towing. There is always an appropriate gear for any speed and load. The paddle shifters which initially seemed like a waste of space are actually very handy for using the transmission for engine braking on downhill grades.
As others have stated, you need to be cognizant of payload on this rig. Depending on your Grand Cherokee's trim level, you will have between 1350 lbs and 1050 lbs available for payload.
